Not all engines or oils are created equal.
The fire district that I am associated with has lost 3 power stroke Diesel engines with the highest mileage being 110,000 mi. In the past 12 months. All 2009 or newer. They are all properly maintained per manufacture specs and schedule. Fluids were checked after every run. Oil sent in and analyzed bi- annually. A little less than 10 yrs ago the district changed oil brand as a result of oil analysis. The oil we are using now shows far less breakdown than the oil we were using.
I’ve been a Ford truck owner all my life. Not so much these days.
Fire trucks are actually a hard use case. Start it up and floor it before it has a chance to get the oil flowing and warm up at all. Then drive like a bat out of hell for 5 miles before shutting down.
Much different from an RV, where you start it up a few minutes before pulling out nice an easy and then getting up to speed on the freeway and running with a fully warmed up engine for a few hours. Same reason semi trucks get 500k out of an engine...it's an ideal use case for maximizing engine hours.
