StirCrazy
Aug 10, 2022Moderator
dodge guy wrote:Reisender wrote:dodge guy wrote:shelbyfv wrote:
Wow. OP posts info useful to other EV owners. The usual goobers jump in with three pages of irrelevant "EVs won't never work." LOL for sure. Kudos to OP for handling the snipes with such grace.
It’s not irrelevant! Let’s see how happy you are traveling 160 miles a day!
F150 Lightning tow test!
I know nothing about the Ford lightning. But when we were crossing the prairies and part of northern Ontario with our EV RV combo a typical day was 500 to 600 kilometres which is pretty much the norm for us. I haven’t watched the ford video. What was the problem?
86 miles per charge towing a 6k lb TT. With a 1 1/2 hour charge time. Not getting very far with a traditional setup!
put the same trailer the op is using behind it and it will probably have more range than they get. the charging speed is a bit disapointing but it is because they are using a 400V battery system so you cant put as high of charge voltage with outmaking heat, but there is suposed to be an anouncment this year so hopefully it is a updated system to compensate for this.
Steve
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.254 PostsLatest Activity: Aug 19, 2026
