Camper_Jeff___K's avatar
Jan 12, 2025
Piston Disintegrated End Of An Engine
Piston Disintegrated End Of Engine
<span;>I found the problem with my engine. The piston in cylinder #5 self destructed  and left no trace behind. All that remains is a rod and wrist pin. The engine ran great until it didn't.  Currently, I'm looking for a new Truck</span;>
  • UPDATE 2 WITH CORRECTION ON CAMPING WORLD
    UPDATE on Camping World price confusion.
    I was asking her about base plates for the truck and the parts lady quoted me for an entire flat tow system installed. We are working on just the parts I need for my setup and I install everything. So that brings the cost to around 3500.00 all said and done. A bit more reasonable. Aparently our good sams membership, doesn't really get us 10% off on purchases. It gets us the advertised sales not available to non members. We also get points on purchases good on next purchases. Better than nothing. I just wanted to make that correction.
  • UPDATE:
    Not getting a lot of love from campung world who wanted 5000.00 to install a baseplate for flat towing.  Something E-Trailer sells for 350.00 and can be bolted in in an hours time. No rental companies have seem to have a truck I can use. Uhaul only has half ton trucks. If I can setup a towbar on this truck, Enterprise has a Freightliner contractor utility truck that can do the tow.
    I'll post more when I know.
  • wow, that fast. usaly they give a little warning...  thats realy to bad after all the work you just did.
    are you going to concider a diesel?  might be able to find a used one for a steel.
  • MORSNOW's avatar
    MORSNOW
    Navigator III
    That's horrible to hear after all of the work you just put into the truck and engine.  Good luck in your search!
