stang233
May 20, 2016Explorer
Just got done. Wow,a pain in the but. But hard. I pb blasted bolts for 3 days and the fine thread still stripped with the impact. I ended up loosening them by hand. Some very important things to look at. Make sure when pressing in the bolts make sure the collar on the backside is perfectly aligned in the hole. This is a job for two people. Also use a ratchet strap to help align the axles . Overall not bad. 4 hrs first side 1.5 second side with help. Make sure u have big breaker bars, put the brass and bolts in tje freezer. Putting the shackles in tje freezer made them worse.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.203 PostsLatest Activity: Feb 25, 2025
