Get the truck that fits your wifes rear end! or you'll never hear the end of it.  Leather seat for her, cloth for me! oops, can't get that option.....
I do not know how heavy that trailer is, so you might be into 45 series territory too! As noted, you need to know the hitch weight of the trailer. THEN< and ONLY then can you figure out what truck you need. A reg cab 25 series that is moderate to lightly specked, can have the same payload as a loaded DW crew cab diesel per the door sticker payload. My 2000 rwd 3 chargeable optioned reg cab vs my 2005 DW crew cab diesel truck. Both by the way were Chebbies! Reality, the DW rig had about 1500-2500 more lbs of actual capacity if I went by axle wt GVW vs the detuned basic gvw ALL of the manufactures work with.
Speed up hills with an equal trailer, one of the three wins a few years, then #2, then #3, then back to #1 brand.....The actual real difference is pretty minor in reality.
GM is typically the lowest entry rig, then Ram a bit higher, Ford the highest entry. If your short, or one of you has hip issues like my spouse, the lower entry rigs are a better option. If you have to lift or carry things into the bed, again, the lower bed height helps save your back. Probably one of the various and sundry reasons why I have preferred GM's over the Dodge-ram/Ford options.
Rear leg room for passengers, hard to beat the Ram Mega cab, Ford crew cab a bit shorter, GM crew a bit shorter yet. Unless you are 6.5-7' tall, probably in all honesty, you're not going to care about the legroom part in the back seat. Choose the seats for grand kids if you have them, favorite 4 legged creature that rides in the back seat etc. Or room needed for extra gear with the seat folded up.
Oh, and Red is the lightest paint color, so always the fastest, Black the heaviest, slowest everything else being equal.......If you believe this, Grit and I have a volcano or three rumbling in our back yards we can sell you!
Have fun shopping!
Marty
