Surgtech94
Jul 10, 2022Explorer II
JRscooby wrote:nickthehunter wrote:blt2ski wrote:You didn’t answer my question.
Nick
I had two 3500 lb tandems, plus hitch wight to work with. Lightest I wieghed was 5300 total.
A semi quick overnight.
Marty
But the better question is - Do you recommend the OP load up his 25 foot trailer with 1400 lbs of stuff and head out on the highway?
But in reality that’s just a hypothetical question also. The real question is “OP, what is the GVWR of “your” trailer.” That’s the real info needed for any realistic advice.
Baffles me why in 4 pages no one bothered to ask that question- instead of speculating about what that trailer should weigh out on the road.
The OP has been using the trailer for a while now right? I think a much better question would be what the actual weight of the trailer is. If it is more than rating, (Likely) might want to adjust. But that is the number needs to tow.
I don’t think the weight were towing is exceeding the 1/2 ton Ram? If the dry weight is 5100#, I can’t believe we have a lot of extra weight, we’ve got our chairs/loungers, cords, solar lights in the pass thru, some pots and pans, toaster, electric skillet, crockpot, blankets, towels, toilet paper, paper towels, minimum dry good groceries. We’re not hauling water in the tank. In the TV, 2 adults, 2 dogs, cooler, small toolbox.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.234 PostsLatest Activity: Dec 08, 2025
