samandjohn
Aug 28, 2023Explorer
Towing
Hello all, just bought my first new toy hauler. I plan on hauling my side by side in the back. I have weight distribution bars and sway bars on a 2 5/16 hitch. Dry weight is 5262 and GVWR is 7,668. Th...
valhalla360 wrote:Turtle n Peeps wrote:
Ok, I'll be odd man out.
I would NOT put the SBS as far forward as you can. Especially if you are towing with a 1/2 ton. That's crazy.
Toy haulers are notoriously tongue heavy and you are being told to make it even more tongue heavy. Sorry, but this is the wrong thing to do.
The best thing to do is put it on a scale and load the SBS where your TH has 15% tongue weight and call it good.
I've yet to see a rear loading toy hauler (there used to be some with a front loading bay) where the toys sit in front of the axles. So the toy isn't going to increase the tongue weight.
The reason empty toy haulers are tongue heavy is to compensate for the fact the heavy toy will be behind the axles and reduce tongue weight once loaded. The OP is putting a very heavy toy (relative to the payload capacity), so he very likely needs to get the center of gravity of the toy as far forward as possible or he risks being too light on tongue weight.
Of course, we see a toy hauler that is likely maxed out or over weight once loaded (he only as 700lb left after loading the toy), good chance he has an under spec'd truck...so far he has not came back and shared any info on the actual truck or trailer. There is a good chance the tongue weight will push the truck over it's payload.
I do agree with you that actually getting scaled weights makes a lot of sense and 15% would be a good target though it may overload his truck. I wouldn't go under 12% though...starts to become a bit of a game when running everything at max.
