This is a removeable DVD stand I made out of conduit and wood for the back bunk in our Jayco 23B. swivels and tilted slightly. I also made one that will slide in the post where our regular TV sits for...
The extension on your drain plug is a sacrificial anode rod. The compounds in the water eat away at the anode rather than the tank of your hot water heater, making the tank last longer, and in some cases improve the smell of the water. (Not all TT hot water heaters have sacrificial anodes.)
Anode rods eventually get "eaten up" and need replacing. The more acidic the water (lower PH) the faster they wear out and need replacement.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
