We got Mods!
shoe shelf in rear cabinet
new shelving above galley with partitions
new shelf above dinette
new shelf in triangular cab by door
plexiglass "splash guard"
plexiglass on side of bathroom cab with wash rags hooks
added "poo" blaster for dry camping. doesn't use much water.
"poo" blaster plumbing showing 3-way valve to select normal flush or blaster
moved the dinette furnace register to end of dinette seat
made furnace grill door operational and added partition to keep items away from furnace
took out the top flip out sponge tray and cut down bottom drawer to make new short top drawer and made new deeper bottom drawer
made shelf with lip to hold plastic "silverware"
purchased new door, reframed and cut new opening into front dead space for additional storage across front of trailer
this shows the depth and it goes from water heater area on left to far right outside wall
moved the door below the sofa from the center to the far left to access space difficult to get to from outside.
put in removable drawer
we made (she made!) solar shades that we can unroll to block bright sun through clear glass without blocking the view!
used a dowel top and bottom inserted in sewn loops. We just reach over to roll up or down
awning lock (cuz I got freaked out about opening awnings reading the forum)
added second battery
battery selector switch
self adhesive soap dishes that hold soap or shampoo, unlike molded in recesses
other little mods:
-spare tire lock
-spare tire cover lock
-propane tanks lock
