I made a flag pole holder for my tongue jack but as it's jacked down in my parking area, the flag hits the ground. Hopefully it will be OK when I camp. I may have to raise it up some.
Also did my "Stinky Slinky" storage mod.
As seen from the front. Drilled about 20 1/8" holes but you can only see these 7. Too small for wasps but large enough for some air flow.
As seen from the rear of the trailer. Drilled 20 1/8" holes for ventilation and to reduce the chance of wasps getting in.
I bent a piece of heavy steel and epoxied a bolt to it to hold the tube to the trailer frame. Used three bolts. May want to remove and relax the bend angle a little if it starts to weat on the hose. I did grind the edges smooth though.
Looking inside the 6" PVC pipe.
