Mr_Usa
Jul 29, 2009Explorer
Show your mods!!
This is a removeable DVD stand I made out of conduit and wood for the back bunk in our Jayco 23B. swivels and tilted slightly. I also made one that will slide in the post where our regular TV sits for...
skippyspad wrote:
I did much the same only using the existing pump, a setup like a winterization kit and a couple extra valves. To access my pump I have a hatch that opens and a small Coleman BBQ slides out. I have about 4 ft of hose coiled under it with a cap screwed on the end. If I have to fill the tank, I use the portable ones, set them on the door step, insert hose. I turn a couple valves so the pump pulls from the portables and pushes into the TT Tank. Works slick.
