Mr_Usa
Jul 29, 2009Explorer
Show your mods!!
This is a removeable DVD stand I made out of conduit and wood for the back bunk in our Jayco 23B. swivels and tilted slightly. I also made one that will slide in the post where our regular TV sits for...
mcallough wrote:epeters wrote:
I had the same concern. So what I did is use some left over 3/4" melamine and cut it to fit between the top of our wardrobe cabinet and the bottom of the upper cabinets up against the ceiling where the TV will go. This allowed me to attach the board via L brackets to the upper and lower cabinet (so nothing into the wall). Then I mounted the swivel mount to the board. Works well. And, since our trailer's cabinets are done in white, the white board matches pretty well.
I can provide a picture if desired.
Erikmcallough wrote:
Has anyone mounted a flat screen TV on a swivel mount? I am concerned as to how to actually mount this because i am not familiar with whats behind the walls (e.g. i need it to be string enough to take the movements). I see allot of people mount them on the cabinet but in my case this is not an option. Of the two walls I can mount it on one is the wall around the fridge and seems weak and the other is the main wall. I suspect the later is the best to mount it on but not sure if either is strong enough.. Any suggestions?
I have a Coachman Freedom Express 17SDX.
Sounds like an interesting idea. I would love to see pictures.
