camp-n-family
Jul 08, 2022Explorer
5100lbs dry? That can easily push 6500lbs loaded. That will exceed the tow limits of most mid size SUVs. You’d be easily within the range of any half ton with a turbo V6 or V8. A tuck will have a longer wheelbase than an SUV and be more stable.
Since you specifically mention a Tundra and buying used I would recommend checking it out. They are reliable and will hold value over the long run. The drivetrain is bulletproof. It is geared for towing and won’t even notice that weight except for in MPGs, it is thirsty. The Taco is a little undersized for what you want to tow.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 03, 2026
