ssthrd
Jul 08, 2022Explorer
camp-n-family wrote:
5100lbs dry? That can easily push 6500lbs loaded. That will exceed the tow limits of most mid size SUVs. You’d be easily within the range of any half ton with a turbo V6 or V8. A tuck will have a longer wheelbase than an SUV and be more stable.
Since you specifically mention a Tundra and buying used I would recommend checking it out. They are reliable and will hold value over the long run. The drivetrain is bulletproof. It is geared for towing and won’t even notice that weight except for in MPGs, it is thirsty. The Taco is a little undersized for what you want to tow.
My old v6 Taco which was rated for towing 6500#, and was pushing it while towing my 5000# (OTR) TT. My Tundra was rated for a 9800# tow, and was pushing it with a 7000# (OTR) TT.
The Tacoma was great for short hauls and flat ground while the Tundra had more than enough power anywhere. Both were gas hogs, and I would not want to pull any more weight with either truck. I’m sure you would be more than happy with a 5.7l Tundra which has 380 HP and 401 ft lbs of torque.
More weight than the 7k that I had behind the Tundra, and I would think about a ¾ ton in your favourite flavour. The trailer was 30’ tongue to bumper, and was a bit of a handful on a windy day.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 03, 2026
