In the process of purchasing a 2016 Jayco Alante with V10. Plan to tow a 2011 Frontier (Automatic) after I have the drive shaft disc. installed as well as Blue Ox plates, brake actuator and etc. The t...
How do you know you have the capacity to tow all 5klbs? I can't find GCWR for your MH. Have you weighed the rig loaded for travel and subtracted from the GCWR? You may find you don't have that much capacity. Your tow capacity is the LESSER of the weight of the MH loaded for travel minus your GCWR or the hitch rating. I assume this RV has a 5k hitch but that does not mean you can actually tow that much. You have to weigh it and do the math.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.254 PostsLatest Activity: Aug 19, 2026
