In the process of purchasing a 2016 Jayco Alante with V10. Plan to tow a 2011 Frontier (Automatic) after I have the drive shaft disc. installed as well as Blue Ox plates, brake actuator and etc. The t...
I run in T/H whenever I start the MH. The MH is always loaded, so it’s always hauling. Your expectation of 7-8 is a bit optimistic. Expect 6, 7 if you’re lucky! Knesset you drive 55 on every interstate out there.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.254 PostsLatest Activity: Aug 19, 2026
