Onyrlef
Apr 09, 2022Explorer
Tow vehicle
In the process of purchasing a 2016 Jayco Alante with V10. Plan to tow a 2011 Frontier (Automatic) after I have the drive shaft disc. installed as well as Blue Ox plates, brake actuator and etc. The t...
FloridaRosebud wrote:lawyers and bean counters most definitely have a say in stuff like this!Onyrlef wrote:
Is your Ranger automatic? If so are you doing the driveshaft disc. or the pump. How are you going to handle braking? Guessing you should be okay on weight even w/the Harley.I've always heard those limits are from the lawyers anyway and you can fudge on them some. Doubt I'd be in TH without a dinghy but I'll definitely use it when towing, it knocks mileage down a bit but is a transmission saver. I don't plan to cruise at over 58 anyway.
Those numbers are from the engineers, not lawyers (I'm an engineer). While there are safety factors it doesn't mean you should ignore them. The lawyers will sue you if you do.
Al
