In the process of purchasing a 2016 Jayco Alante with V10. Plan to tow a 2011 Frontier (Automatic) after I have the drive shaft disc. installed as well as Blue Ox plates, brake actuator and etc. The t...
For the Ford Ranger automatic there is a kit that will make it towable without a drive shaft disconnect or pump. It is called the Neutral Tow Kit (NTK) available from Ford. Check to see if it will work. Also, you will need a reprogram of the ECU.
We have used one for 4 years, ours is a 2011 Ranger 4X4. Works well.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 09, 2026
