APT
Apr 12, 2018Explorer
If tow rating is 4500 pounds, you'll want to target closer to 3500 pounds. For towing any high walled RV, make sure your vehicle has a heavy duty transmission cooler. Pulling two sheets of plywood through the air at 60mph takes a lot of power, which means the trans shifts a lot more than just the truck itself. The 8-spd trans will keep the engine in closer to it's peak torque, so expect a lot of time towing in the 3000-5000rpm range. IF that scares you, get a low walled RV or different vehicle.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.254 PostsLatest Activity: Aug 19, 2026
