handye9
Apr 12, 2018Explorer II
When loaded for camping, that trailer will be closer to (if not over) 5000 lbs, with tongue weight in the area of 600 lbs.
Look at the tire / loading sticker (on drivers door post) for the truck, as it was leaving the factory. You'll find a number for "max occupant / cargo weight" (AKA payload). That is the truck's capacity to carry the combined weight of everybody and everything that gets added to the truck. That includes aftermarket accessories (undercoating, bed liners, bed caps or covers, etc) that you or the dealer have added.
Check your hitch receiver. It has it's own ratings for dead weight being carried and one for weight with a weight distributing hitch.
The weight of your hitch equipment and trailer tongue weight are counted as cargo weight in the truck. If you're using a weight distributing hitch, that weighs 80 - 100 lbs.
Your payload number should be high enough to support the weight of your family, pets, any cargo in truck bed, and up to 750 lb from hitch and trailer.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.254 PostsLatest Activity: Aug 19, 2026
