TurnThePage
Apr 12, 2018Explorer
Obviously the towing platform is very up to the task. The drive train is where it gets a little hairy. I believe you will be perfectly safe if you've taken the standard precautions with maintenance, hitch setup, tire inflation, etc. But you really will be under powered, which will be most noticeable on hills. I bet it could be done just fine, but I wouldn't want to be the one doing it.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.254 PostsLatest Activity: Aug 19, 2026
