Lessmore
Apr 12, 2018Explorer II
The Dodge 3.6 liter V6 has 305 hp, an 8 speed transmission. Yup the hp comes at high rpm, but then the Mopar V6 does have dual overhead cams, 4 valves per cylinder. A few decades ago an engine with features like DOHC, 4 valves per cylinder and 305 hp out of 3.6 liters...would be a very expensive European sports engine.
Back a couple of decades ago...the big OHV...2 valves per cylinder V8 in a Dodge truck was the 360 (5.9 liter) engine...it pumped out 245 hp, 330 ft.,lbs of torque, the Dodge 4.7 liter truck engine was good for 250 hp, but less torque at it's best rating. And they only had 4 speed transmissions!
So you got twice as many gears...over 50 more hp, less torque...probably about 50-60 ft. lbs in the 3.6 liter Dodge truck engine.
I dunno what Mopar rates the Dodge V6 truck engine's tow rating at...but I would assume the 3.6 can handle the rating.
Technology has made a difference.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.254 PostsLatest Activity: Aug 19, 2026
