ls1mike
Sep 21, 2023Explorer II
blt2ski wrote:
Mike
Not too many folks posting recently. The few that have posted about them like them. Better than the 6sp you have.
Being as the 10 sp has a 4.5-1 fist gear vs the 6 @ 4.1-1. Going with a 3.73, ene a 3.42 will have as much or more go power as you current rig. Lower rpm at 60....
I'd probably choose a 3.73, or the 4.1, only because I've put a 1-2" larger diameter tire on the last few I've owned. That 2" tire changes GR from a 4.1 to an effective 3.73. An inch to a 3.95'ish ratio.
Go buy one, don't look back!
Marty
Thanks Marty.
Looks like the only gear ratio available for 2024 is the 3.73. Everything I have seen or read says good things and MPG is way better than my old 6.0. I am bummed the 17 got wrecked I looked for that truck for 3 years. I wanted a long bed with rubber floors and limited options. Hard to find rubber floors and a long bed right now.
So I am looking at 2 3/4 ton on LT one custom and on 1 ton custom. Both out the door for under 63,000. Truck prices are stupid. :( Which hurts my soul as I am not a truck guy and don't daily drive it. Maybe it gets 3000 miles a year on it, 5000 on a heavy year.
I was out camping when this happened. My 17 year old son has a 2003 LB7 Duramax he came out and towed the trailer home. To be honest it is a good truck with 227,000 miles on it, but it really didn't tow the trailer much differently then my 17 did. So I decided I just don't need a diesel. 401 HP and 464 FT/lbs of torque should be plenty for the trailers I tow. The heaviest being about 8200lbs.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
