Vintage465
Oct 01, 2023Nomad
ls1mike wrote:blt2ski wrote:
Mike
Not too many folks posting recently. The few that have posted about them like them. Better than the 6sp you have.
Being as the 10 sp has a 4.5-1 fist gear vs the 6 @ 4.1-1. Going with a 3.73, ene a 3.42 will have as much or more go power as you current rig. Lower rpm at 60....
I'd probably choose a 3.73, or the 4.1, only because I've put a 1-2" larger diameter tire on the last few I've owned. That 2" tire changes GR from a 4.1 to an effective 3.73. An inch to a 3.95'ish ratio.
Go buy one, don't look back!
Marty
Thanks Marty.
Looks like the only gear ratio available for 2024 is the 3.73. Everything I have seen or read says good things and MPG is way better than my old 6.0. I am bummed the 17 got wrecked I looked for that truck for 3 years. I wanted a long bed with rubber floors and limited options. Hard to find rubber floors and a long bed right now.
So I am looking at 2 3/4 ton on LT one custom and on 1 ton custom. Both out the door for under 63,000. Truck prices are stupid. :( Which hurts my soul as I am not a truck guy and don't daily drive it. Maybe it gets 3000 miles a year on it, 5000 on a heavy year.
I was out camping when this happened. My 17 year old son has a 2003 LB7 Duramax he came out and towed the trailer home. To be honest it is a good truck with 227,000 miles on it, but it really didn't tow the trailer much differently then my 17 did. So I decided I just don't need a diesel. 401 HP and 464 FT/lbs of torque should be plenty for the trailers I tow. The heaviest being about 8200lbs.
Regarding the horsepower and torque figures you mentioned. Those are good numbers. The big difference between gas and diesel is where the torque is developed in the RPM range. My 2013 Duramax developes 765 lb/ft. of torque, but it is at 1600 RPM. That's called real easy and quiet uphill towing. And the exhaust brake is nice going downhills. But if you don't do a whole lot of mountain towing, the gas engine should be great. Please, no one get mad here, just my thoughts and opinions.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
