Camper_Jeff___K's avatar
1 year ago
VIDEO FORD 5.4L 2V Timing Chains Chain Guides And Chain Tensioners Installation
I show you How To Quickly and Easily Install new Melling Timing parts on a 2000 FORD F-250 5.4 Liter 2 Valve engine. And Similar Vehicles. 1. Be sure to pull the lock pins from each of the chain tensioners after they are torqued in place. 2. Follow Ford Torque Specifications. 3. Get the Crank Alignment Tool To Position And Hold Your Crank In safe position to prevent valve damage. 4. Dab a little RTV Silicone into the Harmonic Balancer Keyway to seal it from leaking oil. 5. Be Sure To Replace The Crank Position Sensor Toothed Wheel. It goes on one way with Front being labeled. 6. Double check everything is correct, installed and torqued before final assembling and covering.
No RepliesBe the first to reply
