JW2ExplorerJun 19, 2013¾ ton vs 1 ton SRWI am looking to purchase a new truck, probably later this year. In the Ford brochure under the heading of “Mechanical” it lists “Rear Suspension” and shows “Axle rating, 6,200 LBS (F-250); 7,280 LBS (...Show More
JIMNLINExplorer IIIJun 20, 2013Jacobs doesn't make a exhaust brake for the 6.7 Cummins. Exhaust braking as the Ford and Chevy is done through the turbo.GM and Ford uses the VVT turbo (variable vane technology).Cummins uses the VGT turbo (variable geometry tech) with a sliding nozzle.
Related Content1 ton SRW debate1 Ton SRW ChallengeThe only real SRW “One Ton” that isn’t really a 3/4 tonHalf ton towing1 Ton SRW Truck
