Iraqvet05 wrote:
Your TT is 5600 dry lbs. What's the payload on either of those trucks?
In all honesty I really haven’t checked. The previous owner of our TT towed it with his 2012 F-150 with 5.0. I don’t believe I will exceed the payload on either truck, might be pushing it on the Ram.
On edit, after checking the brochure from Ford, it is around a 1700lbs payload. Max tow rating with 3.55 gears is 7700lbs. On a hunting trip the TT isn’t loaded very heavy at all, maybe 6500lbs. It’ll be a load but not too bad for an occasional trip. IF I get too worried about it I can always regear to 3.73 and take advantage of the 9300lb tow rating with that gear set.
