joerg68
Dec 21, 2018Nomad III
The FWC is very, very rugged. If you really want to go offroad, that could be an advantage.
If and how much offroading you really want to do with a fullsize, crew cab truck with any type of TC in the back, you will need to find out for yourself. Member jefe4x4 offroads with a conventional Lance hardwall camper, so it can be done. But I have also seen pictures of a stripped tiedown anchor on a popup camper on this very forum.
Back in 2012, I visited Hallmark and Outfitter. I was impressed with Hallmark as a company, and I liked the product. I believe they give you a choice of wood, aluminum or Coosa for the frame. I like their campers, and the build quality I saw at the time was very good.
I had an Outfitter Apex 8 myself. It is a very well thought out design. Build quality was somewhat mediocre, but it was a great camper and it held up well. I had it on a Silverado 2500 single cab, long bed gasser. Even without any modifications, the truck handled the camper very well. Although they are on the heavy side for a popup, the cog is very low, which helps with handling.
The camper worked well in freezing temperatures (-5 Celsius), but with the aluminum frame you needed to watch for condensation.
Re. towing with a hitch extension: why else would you have one? As long as everything is within specification, where would there be a problem?
