- jimh406Explorer IIIBut you can buy it local, too.
americanrascal wrote:
I saw a tiny spot on the screen while reading this thread. I keep rubbing and rubbing the screen trying to remove it and it won't go away. Any ideas how to get it off the screen?
A sharp 1/8" drill bit and a cordless drill.
Just push until the chuck is touching the screen and the spot will be gone.
Works every time.- BedlamModeratorWhite Out
- americanrascalExplorerI saw a tiny spot on the screen while reading this thread. I keep rubbing and rubbing the screen trying to remove it and it won't go away. Any ideas how to get it off the screen?
- NRALIFRExplorer
JoeChiOhki wrote:
I too had this problem, but I discovered that it was easily fixed by setting fire to it.
But only if whacking it with a mallet, prying on it with a screwdriver, and drilling a hole in it don't work first.
If fire doesn't do it then you move on to pulling out the big guns (Literally. I had to resort to this level of intervention with an electronic musical doorbell on a house I once owned that refused to cooperate), then finally.........explosives.
I've never had to resort to that final level.
:):) - Buzzcut1Nomad IIFrom my perspective all the comments have been spot on in regards to the issue at hand.
- Reddog1Explorer II
JoeChiOhki wrote:
Is that another method of Flaming?
Wayne - JumboJetExplorer
Boatycall wrote:
In order to truly understand what the OP means, you'll have to check this thread right here
I checked that thread and even though it starts out making a very specific and identifiable point - I still have to stand my ground and say "Point not taken!" Is it still there? - JoeChiOhkiExplorer III too had this problem, but I discovered that it was easily fixed by setting fire to it.
- BoatycallExplorerIn order to truly understand what the OP means, you'll have to check this thread right here
44,030 PostsLatest Activity: Feb 04, 2025
