time2roll
Sep 01, 2017Nomad
+1 to just pump the waste up into the tank sitting in the truck bed.
Voltage drop is hard on these 12v pumps. If you are not prepared to make a permanent mount connection I would just make up a custom cable with battery clamps on one side and an Anderson connector on the other. Probably #6 wire.
Custom wire custom premade here: http://www.genuinedealz.com/
You will need to call and explain what you need.
