RayMc
Apr 04, 2016Explorer
Brewurown wrote:
I install a valve under the bed. Installed a toggle switch on the dash connected to the switched power. I didn't want the valve on if I should forget to turn off the switch. It's been installed now for almost a year, made 3 trips between NC and FL with no problems. I used this valve:
valve
Could I ask why you chose a 1/4" ported valve? The RDS kit is 3/8" tubing and fittings. Did you support the valve or just let the hose carry the load? I have a new Ford SD with upfitter switches so wiring should be a piece of cake.
44,056 PostsLatest Activity: Jul 04, 2013
