kerrlakeRoo
Aug 18, 2018Explorer
What Cramden said was correct for aligning the axle to the trailer frame for a single axle, and then it is a matter of ensuring that the second axle is parallel to the first.
In your case the axles are not described as parallel, which can be checked for potential tire cause by measuring space between axles.
I just did a quick google search, and the 1/8 inch measurement appears pretty close for the axle to frame requirement, but the paralleling of the axles should be near perfect.
