budwich
Aug 18, 2018Explorer
As previous suggested, your measurement may not be "good" depending on the conditions that it was done under since the suspension may not be totally at "rest" / "neutral" position. You may need to pull it to a long flat surface and travel in a straight line for a bit to allow the suspension to "set", then measure and see if it compares, then repeat and compare once more. If it is out after that, as suggested, you should potentially get it looked at for suspension check (loose components) and ultimately an alignment.... otherwise, you may be eating tires in quick fashion down the road.
