goducks10
Aug 18, 2018Explorer
Ralph Cramden wrote:
Unless you have the trailer sitting on a 100% level surface, the trailer itself perfectly level and perfect as far as measurements from frame to level surface, along with some other things, you can not determine alignment in any accurate way. Even with all that done you're only doing half arsed guessing. There is enough play in the suspension, movement in the equalizer, differences in the tires etc to throw of your results to the point of them being worthless. The spread on the tires changes with equalizer movement on a conventional leaf spring setup, or with travel on a torsion arrangement.
The only way to determine it is accurate measurements on the frame from the center point of coupler or A frame attachment points to the spring hangers or axle attachment points.
x2
