Huntindog
Aug 18, 2018Explorer
Dr. Feelgood wrote:Measuring the way you did it is worthless.
Just bought new twin axle TT. When measuring between the tires on each side there is about 3/8 in difference.Some component of the axles,tire mounts or such must be slightly out of parallel. Salesman said no problem. Is that enough to be concerned about?
The distance between the tires is constantly changing as the equalizer moves. It is next to impossible to get an accurate measurement because of this.
Measure the spring hanger locations. There are several methods, some mentioned here already.
The hangers will not move,(unless broken) so that measurement can be relied upon.
