Ralph_Cramden
Aug 20, 2018Explorer II
RCMAN46 wrote:
"As far as dropping plumb bobs to floors that may get you a measurment thats close to accurate, but it may not. "
I am open for a method that will give more accurate measurements.
Your method is probably about as accurate as needed or your going to get. Unless you want to find a true level and flat surface, get a bunch of jack stands, and account for unequal weight loading as well as frame camber.
All that is probably for naught as these things are junk and have a ton of flex and twist when going down the road, not to mention a good amount of both most likely built in as well.
