rowekmr
Jan 08, 2015Explorer
03 Navigator Cold Weather Operation
Just got a 03 Navigator (project) with 5.4 4 valve engine with 116K that suspension and some options were inop. After shop diagnosed and replaced fuse box, air compressor relay and door switch the air suspension and a few other power options are working tip top. Lately the temp been in single digits (4-7F) and I notice if I start it completely cold and just let it idle (20-30 min) the coolant temp gauge will just move a little bit off of the bottom hash mark and the air will blow warm not hot. Once I get driving it will slowly climb to the bottom of the thermometer in the gauge and the air will blow hot. If I sit idling the gauge will go down some and air will cool slightly but still stay warm. Is this normal or could the thermostat be going bad and/or need a coolant flush. I wondered if this has anything to do with an all aluminum engine dissipating heat quickly?
