SouthpawHD wrote:
"You're going to have around 700lbs of tongue weight from the trailer, which will leave you 500-600lbs of payload capacity for everything/everyone else in the Tahoe."
As the poster said above, the tongue weight could be a limiting factor for you. Be sure to check the tongue weights of those hybrids as many of them can be dramatically different. My Jayco hybrid is pushing 900 pounds of tongue weight!
Thanks SouthpawHD, the newer of the two has a tongue weight over 600lbs! The '08 Stampede is only 411. That will definitely be more a part of the discussion since mkirsch brought up the point earlier too. I'm not opposed to the used TT, but the DW is pretty convincing, and also pretty set on the new '16 model. Numbers don't lie though, so we may end up with the cheaper choice of TT being the best fit.
