more fodder. THis per Dodge TSB 19-008-03 dated 11/28/03
Symptom/Condition:
A vibration may be felt in the steering wheel and/or the accelerator pedal on Diesel engine vehicles with the engine operating between 2000 and 2200 RPM.
Diagnosis:
Operate the engine between 2000 and 2200 RPM. If the vibration is present, perform the Repair Procedure. The vibration may be more pronounced with the A/C compressor on.
Parts Required:
Qty. Part No. Description
1 52113926AF Power Steering Hose - Pump to Hydraulic Booster .
I had this on my new '03 Dodge/Cummins. Really bad vibration in the steering wheel and the go pedal.
The fix was a new hyd hose with about 2 lbs of weight crimped to the hose to dampen very severe hyd vibrations. I thought the '04 had this fixed on assy line but won't hurt to check.
