TReinerExplorerMay 28, 2015'04 Suburban (power at the trailer connector)Hey guys, Thought you RV guys might know the answer here,, One of my hobbies is RC Model airplanes, I built a extension harness that takes power from the 7-pin connector so I can use the 12v. for m...Show More
stew47ExplorerMay 28, 2015Did you put in the maxi fuse under the hood? Is the ground ok at the 7 way?
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???"Service Trailer Brake System" message on Suburban2021 Suburban. How Much Trailer?Travel Trailer2500 Suburban towing 31' Travel Trailer
