kerry4951
Aug 02, 2013Explorer
Grit dog wrote:
Thanks for all the replies.
I heard the heater vents into the basement. Will verify that and look at provisions for any lines that seem like they may be unprotected or not receive any heat.
So no problem driving with the furnace and water heater on? I know the fridge will stay lit so presume the rest will.
Good points about insulation around the slider too.
Thanks, ill start diggin into it this fall.
Furnace does not actually vent into the basement in any AF. Some of the different manufacturers do run a direct heat duct into the basement. Thats still the better system. AF uses a small computer fan to draw warm cabin air into and thru the basement. Fan only comes on when the furnace is running, although I as well as a few others have installed a double pole switch so the fan can be turned on with or without the furnace running. If Im parked and have full hookups I use an electric baseboard heater and I can still run the basement fan to keep heat circulated around the tanks.
44,068 PostsLatest Activity: Jun 10, 2026
