ivbinconned's avatar
ivbinconned
Explorer II
Jul 12, 2014
06 Ram 5.9 code Po251 ??
Engine light comes on and it will do a hic-up but keeps on running just fine??
It has been suggested I change out the fuel solenoid at the pump.
Help???
    Help???
    Check the fuel pressure going to the injection pump and then the pressure going back to the tank. Possibilities are, pump regulator control or injector pump fuel valve feedback. Chrysler training video. Chrysler Master Tech videos
    Don
    If anyone needs a laugh watch the old videos Like this one LMAO/ROTF
  • P0251 - CP3 Pump Regulator Control; Injector Pump Fuel Valve Feedback: The ECM detects a discrepancy between PWM supplied to FCA and PWM returned from FCA.
    Possible causes:
    - Intermittent condition
    - Fuel Control Actuator
    - Return wire open from FCA to ECM
    - Supply wire open from FCA to ECM
    - Supply circuit shorted to voltage
    - ECM
    Also check the 15/16 nuts on your injector tubes, sometimes they're loose and will throw that code.
