bob213 wrote:
Should I be using ProFlex on the bottom of the frame on my shower? I tried silicone and it wiped off the next time I dried down the shower.
Many manufacturers of shower stalls and tub enclosers for home and RV's say use silicone. I have had it work great on some and then on others have had the same results as you with it peeling off in days. On one encloser I had caulked using the recommended silicone and it peeled, so I contacted the manufacturer and they stated that the shower stall needed to be wiped first with a cleaner (I cannot remember the type, I am thinking rubbing alcohol but don't quote me) to cause the silicone to get a hold on it. Did that and it worked great that was 8 years ago and it is still sealed.
