sasquatchgeoff
Jul 06, 2016Explorer II
2oldman wrote:sasquatchgeoff wrote:Why not? How do you run your air?
I did not want to use the inverter/charger as an AC pass-through.
I used a separate breaker panel with a 30 amp breaker which gets thrown to ON when I am on shore power - this closes the circuit for the shore power, i.e. "everything" and provides the normal shore power setup, otherwise, if I run 30 amps through an inverter (even in pass-through mode!) that is only rated for 15 or 20, I was concerned that the wiring in the inverter would not be heavy enough for the task.
44,067 PostsLatest Activity: Jun 03, 2026
