RCMAN46 wrote:
06Fargo wrote:
Who would take this route? Me... I would haul an RV over that pass to get to the other side and plan to one of these trips... it looks like a perfectly good road and beautiful scenery - just uphill for a bit...
Spoiler alert: The turbocharged engine "wins" at 10,000 - 12,000 ft elevation.
check the 14 minute or so mark of this Ike test - diesel pickup towing for all it's worth and a class 8 most likely running empty at about 30,000 lbs comes along -
Same HP more torque?
If you look at the video close you may have to agree the pickup got caught in traffic and had to let the class 8 go by before he could move over. Also look close and you will see the pickup does move over to pass what ever was in front of him as soon as the class 8 is clear.
If we could see all of the footage uncut we may even see the pickup pass the class 8 later on.
Same horsepower? not likely.
Yes that could be - usually these presenters will make a big to-do about getting caught in any kind of traffic that affects their time up the grade - and I expect even do-over a run - because they say the intention of these runs is a timed "race" up the hill at max vehicle speed or held at the speed limit, whichever the truck will do. The class 8 could be 500+ hp - 450hp is the most common engine in this type of 5 axle service.
The class 8's engine will have 2x the torque of the Duramax but suggesting that has anything to do with the speed it is pulling this grade will just start a uproar here on the rv.network :) cause hp is hp and torque don't matter in a tow mobile...
I drive both types of vehicles and one pulls a lot better than the other at the same weight, no traffic, same hill... but I can't say :)
Anyway back to the OP...
