JCR-1ExplorerSep 01, 2013110 Volt grounding ???Why is the trailer metallic skin or metal frame parts not grounded back on 110 Volt. Is this because it is also the ground for the 12 volt system ??
BB_TXNomadSep 01, 2013The trailer frame and any other metal parts should be grounded via the green wire safety ground of the power cord.
Related Content12 volt only refrigerator12 Volt Power Issue110 volt TV, vs 12 volt TV?No 110 Volts to Hot Water Heater ElementNo 12 Volt without converter
