- TTBeachBumExplorerThanks for those comments, you answered my next question about the ride. What tires did you upgrade from? Did the upgrade compromise the integrity of the truck?
- turbooExplorer
06Fargo wrote:
I am often hauling at max weight for Rge E tires - no like - changed to 19.5 Rickson's/tires to have reserve tire capacity. Very nice increase in stability, not so much need to air up air down, heavier the load the better the truck handles, wear indicates they are going to last a long time. Great on snow, ice, and gravel too. We stay out of soft sand.
Main disadvantages: cost (but ok vs changing trucks), sidewalls are strong = stiff - truck rides like E's with 75psi & tires follow parallel cracks and ruts in pavement so the truck "ducks around" more than before. Tire/wheel combi is heavier than stock so fuel economy suffers a bit, especially in stop 'n go.
Effective gear ratio went up just over 5% due to increased diameter - this was an advantage on our truck.
everything like you said :C
except I don't a have darty duck feeling - notevenExplorer IIII am often hauling at max weight for Rge E tires - no like - changed to 19.5 Rickson's/tires to have reserve tire capacity. Very nice increase in stability, not so much need to air up air down, heavier the load the better the truck handles, wear indicates they are going to last a long time. Great on snow, ice, and gravel too. We stay out of soft sand.
Effective gear ratio went up just over 5% due to increased diameter - this was an advantage on our truck. - TTBeachBumExplorerWhats the grade?
- dadwolf2ExplorerI feel like the "Lone-Wolf" responding here!! Tires do seem to be the weak link. A set of Rickson wheels and tires are in the $3500-ish range. Vision 81 wheels and locally purchased tires will be less expensive.
- TTBeachBumExplorerSo the only altetnative is to upgrade the tires to a f rating then
- dadwolf2Explorer
TTBeachBum wrote:
Thd total dry we8ght is 3400; thd truck is tc certified for 2920 dry weight. The F250 is a lojg bed, and no have not seen the unit, it would be ordered if the fit works,
OK, so the loaded camper weight will easily be over 4,000 lbs. - TTBeachBumExplorerThd total dry we8ght is 3400; thd truck is tc certified for 2920 dry weight. The F250 is a long bed, and no have not seen the unit, it would be ordered if the fit works,
44,054 PostsLatest Activity: Dec 15, 2025
