- sandyeggo1ExplorerTrying again to show wing rot
- sandyeggo1Explorer[img]
[/img]
Trying to show wing rot here, but failed again, sometimes it will work.
Slide out has been moved to the inside. - AnEv942NomadNot sure how your trying to post pictures. From 'reply to topic' or the 'advanced form post" links-should bring up the advanced editor window-use the image button-paste in the url (http://xyz.com/mypicture.jpg)no other codes. Your links are correct just coding for display getting scrambled?
By last picture-have you removed the slide out? - sandyeggo1Explorer
This joint at 8" leaks. This metal sill holds water and was not set up to drain to the outside.
- petoworxExplorersecond that ,check fridge drain i had the same trouble
- sandyeggo1ExplorerTrying to post video of tip out gasket leak
- RaftenExplorerI would suspect the fridge drain as the water source.
44,052 PostsLatest Activity: Oct 29, 2025
