just purchased 10 1141 led lights on ebay for 26.00 with free shipping installed in my camper with 5 lamps on draw was .9 amp.the light is white and seems to be brighter than the standard 12v lamps.if...
'Warm white' is the general term used for color most want. Look at voltage range also, better ones (or ones you know will last) will be rated way over what can be seen in rvs when charging at more than 14.x volts. Lumens, though a relative measurement, is good for comparing expected light output if known.
