theoldwizard1 wrote:
Blowing smoke ! Nothing wrong with good quality tires as long as you are not exceeding the load capacity and are keeping them properly inflated.
The smaller the wheel and tire, the faster it spins. The faster it spins, the more important good lubrication is. Every time you fuel up, check the temp of the bearing/hub. If you are spitting lube or you can not put your hand on it for more than a second, it is time to re-lube/replace the bearing.
An extra 2 sets of bearings are cheap insurance. Tools/grease to do the job are cheap insurance. A second (even unmounted) spare is also cheap insurance.
eTrailer does not sell "junk". Call them.
Thanks for your reply, sir. I had been mostly following your advice, especially on the return trip with the new bearings. The hub temperature was never more than slightly warm to the touch, but I might have pushed the limits a bit on the stretch before the bearings went - we were going from Edmonton to Fairview Alberta and we pushed the speed a bit more than the rest of the trip - probably a long stretch of 70mph did them in. From now on, we'll check this every single stop. I'll certainly be bringing 2+ sets of spare bearings, possibly including fully set up and grease packed hubs as we have a lot of storage we haven't been using. I don't want to get gouged again on part costs. The place we had the work done had a reasonable shop rate, but charged 150+ (CDN) for the four L44643 bearings and another 50+ for two seals.
Very good to know about the tires. I can get 145-12" radials that will almost drop in fit for the 5.30-12" that are on it - and keep the speed down below 65mph for sure. What are your thoughts on Bearing Buddies in this kind of set up?
